smeaks
Further to my recent vetus post, i now understand what the vetus anti siphon does and recognise that mine is leaking a little water. My exhaust discharges below the water line (Moody 27) and therefore I can not easily check for water discharge in the exhaust to check for cooling flow of water through the engine. If the vent on top of the vetus is lead overboard what needs to be done to the vetus to make a tell tale flow appear at the vent? If the tell tale is through hulled well avove the waterline then it would still serve the purpose of an anti siphon but would the evident flow detract sufficiently from the main cooling supple to cause a problem - the vetus is mounted before the engine.
