Reptile Smile
Post 54 above you?
I've always wondered why no one suggests a small generator such as the eg screwfix IMPAX IM800I 700W INVERTER GENERATOR 230V at £189.99 and say a 500 watt electric heater. (I just picked the cheapest 4 stroke inverter I could easily find). The generator like an inboard engine on bigger boats could be used for an few hours to heat things up, and as and when necessary also for recharging the on board battery making toast. The sky's the limit. And it would use the outboard normal fuel.
Bare at
Not suggesting the OP fits one, but my D3L is barely audible unless it is on full power, which isn't often. I don't see the point in having it on all night anyway, the timer turns it on a little while before the alarm goes off. As for current draw, your memory might be a little rusty, mine draws about 2 amps.
That's just terribly exaggerated, we got the odd post, mostly from people who have badly fitted systems. Considering how many are in use, they are very reliable. Mine was fitted in 1988 !
So how come there's yet another plea for help by an Eberspacher owner running right now then ?!
Heating and ventilation on boats is always a balancing act, very much like a thermal version of plate spinning.
Lots of interesting ideas. Cosy woodburners, hi tech eberspacher, physics defying night lights. Comments so far, anything needing mains power would require an extension lead approximately half a mile long (assuming that the nearest householder would let me plug in), blown air or drip feed would necessitate a diesel fuel tank (I presently have only a plastic 5 gal outboard tank). I'm going to try the Tilley lamp which has several advantages - the main being that I already have one in the garage. The noise and excessive brightness may interfere with listening to the radio.
I think that means an inboard for charging, but I'm open to persuasion that solar or some sort of really quiet buit in generator, or a wind gen or something else might be viable.
You'll need to things, adequate fuel supply, i use 40 litres a week if it's on constant, and enough panels. Mine draws about 2a.
I had one on a previous boat, I never ran it for more than a few hours a day. So the fuel tank does not worry me.
The electrical needs are more of an issue. Places I am likely to go, how much will I really get from solar panels? Let's say late season up the River Dart or Fal. A few dull days between steep wooded banks in November? Plus there will obviously be other electrics needed, like lighting.
I am going to risk the wrath of the diesel fuelled warm air heaters...
GM's boat to be heated is small. I doubt whether the main cabin volume (judging by my daughter's 20ftr) is much bigger than a MPV. There is no overwhelming need for heated air in such a cabin, and the surface area/volume ratio is much smaller than bigger boats.
In turn that means the people inside are much closer to a heat source than on a bigger boat, so radiant heat is significantly more effective.
Night storage heaters use bricks made of magnetite which absorbs heat (being metallic) in large quantities.
If GM made a steel box to contain a number (2, 3, 4) of these bricks, and put it on a stove either in the cabin or in the cockpit, the bricks will absorb heat from the gas/spirit stove until they are almost red hot. This will take some time.
GM than takes the box with the hot bricks, places it carefully on the cabin floor, and sits back enjoying lots of radiant heat and also some hot air (similar to the forum). The bricks will stay hot for a long time.
While in use, the bricks do not give out carbon dioxide, carbon monoxide, carbon nanoparticles (like candles do), and can be re-used almost ad infinitum.
Hot bricks (or rather cold hot bricks) can be stored out of the way until needed, do not need a licence, maintenance, insurance, or a training course, and as such as ideally suited to the small boat sailor. (When I say small, that is not an aspersion on GM's size. For all I know he may be 7 ft tall but agile) )
I commend hot bricks to the house.
You don't get anything for nothing.
Personally I can't stand the smell of parafin and oil lamps and so forth, or the inevitable MAB effect of running such things in a confined space. I think that's why hardcore sailor used to smoke pipes, to cover up that smell?
GM's boat to be heated is small. I doubt whether the main cabin volume (judging by my daughter's 20ftr) is much bigger than a MPV. There is no overwhelming need for heated air in such a cabin, and the surface area/volume ratio is much smaller than bigger boats..
I know what I meant to say and that's what you saidI was trying to make the point that a bit of radiant heat in a small boat is more effective than in a big boat and it's easier for crew to be warmed by proximity.
