alisdair4
I am putting my boat back in the water after a break (work-imposed) of some 18 months. The engine is a raw-water cooled Volvo Penta MD11c, about 26 years old. When the boat was laid-up in Aug 09, the engine was winterised (ie, run through for 30 minutes with antifreeze and water mix). The pump impeller was removed, and the fan belt slackened. I intend to re-start the engine this coming weekend to save time when it comes to the launch week in April.
I will do an oil and filter change after the engine is running (ie, the oil is hot).
Apart from ensuring that the engine is turned over a few times with the decompression levers out (to prevent premature starting and make sure that there is sufficient oil sprayed around in the engine) is there anything else I should consider doing ?
(it goes without saying that I will provide a cold water feed to the raw water strainer...!)
