Andrew E
AT has lost even more miles now. Heartbreaking to watch.
Guess Alex given up trying to win, settle for second. Not break the boat.
Will he try in another 4 years?
Lates update has AT and ALC on the same apparent wind angle and nearly same wind speed but Armel 5 knots or so much faster????
As others have said, we don't know what they are actually experiencing. A small difference in wind speed, wind angle and sea conditions could make a big difference in speed. They are over 200 miles apart. It would be astounding if they were in the same conditions.Have not seen the data, but you do have to wonder if he has lost one of his big reaching headsails?
Edit - when I look at the "360 degrees" info, ALC has 18 knots from 78 degrees and AT has 17 knots from 67 degrees. The wind is 10 farther forward for AT. That could explain the speed difference.
Yes but they are not sailing the same course, both TWA were 73 degrees. I would have thought speeds to be similar not such a difference as seen here. https://gis.ee/vg/ ALC is 6 knots faster over the ground.As others have said, we don't know what they are actually experiencing. A small difference in wind speed, wind angle and sea conditions could make a big difference in speed. They are over 200 miles apart. It would be astounding if they were in the same conditions.
The wind speeds shown are not actual but the results of modelling. The actual winds will be very different.
The fickleness of the actual winds being experienced are working for Armel but could equally work against him in due course.
We can only hope.![]()
I agree with that. At some point Alex said he was sailing in a breeze on a tack which wasn't possible according to the winds map provided by VG website. This, plus currents, waves and their general state of exhaustion can explain a lot. I am expecting Alex to catch up (hopefully not too much) in the next few days.
Plenty of time yet boys, plenty of time. Keep the faith.
Looking at the forecast, there are a number of holes coming up that could easily trap the unwary for a day or more. .
As has been mentioned above there are plenty of wind holes in complex patterns ahead - so neither is going to romp home and they will be working hard - probably all the way home.
