VDO Rev Counter - Revolution Pick Up Unit (Non Alternator)
RunAgroundHard
20 Aug 2022
On my Perkins 4236 there is a small pick up unit (I assume) with VDO on the front. It is mounted in front of the water pump, is about 3 cm diameter, 4 cm deep, has two wires coming from it, both white. I am trying to find either a replacement or establish how it works. It may be a magnetic pick up but I don't know. The engine has two ancient alternators on it and I am sure that the RPM is not taken from them. The problem I have is that the Rev counter goes to full scale when the engine starts to rotate, not when the ignition is powered up.
I have searched the internet but can't find anything. I did find a video on replacing a perkins 4236 engine and it had the same device. Does anyone know what I am describing, can they help with a picture or description, or even a link to where I could find one? I tried swapping the wires over but the VDO still maxed out. Does anyone know how these devices work?
The engine is from around 1973.
Thanks in advance.
Alex_Blackwood
19 May 2003
Fareham
Thanks in advance.
Picture may help!
RunAgroundHard
20 Aug 2022
Found this image from YouTube
. The device on my engine is the same as the round device on the right hand side as you look at the picture, below the "rk" in Perkins.
Alex_Blackwood
19 May 2003
Fareham
Thanks for that. Looks like it is a mechanically driven Generator producing a pulse related to engine speed, just as the alternator
Frequency increases with RPM. Llke you I cannot find any reference to this unit. Maybe that the display would work if connected to the alternator W connection. If you have, or can find a multimeter with frequency function you maybe able to get an idea of the output of your unit.
harvey38
27 May 2008
It's a Hall Effect sensor that provides a magnetically driven pulse to the tacho, I have them on my Ford Sabres driven by the injection pump. If your tacho goes to max when the ignition is turned on, it sounds like you have a short somewhere, if you have a twin installation, you could swap gauges to see if the short is internal.
RunAgroundHard
20 Aug 2022
Thanks everyone for your feedback. When I am at the boat (this weekend I hope) I will investigate further. The information provided should help me troubleshoot the problem.
Alex_Blackwood
19 May 2003
Fareham
Are you sure? I purposely used the term generator as there is no external indication in the pictures to identify the type. Anyway that is splitting hairs , no criticism intended. I just thought that with a possible elderly engine it would be a small ac output device or even just a cam operating a set of contacts, Unlikely but not unknown. Don't even know if the unit can be opened up?
VicS
13 Jul 2002
More likely to be a small AC generator, as you suggested ,than a Hall effect device because a Hall effect sensor would require distinguishable connections for a power supply and a signal output but the OP says it has just two white wires.
harvey38
27 May 2008
Only going from what I was told when ordered one when mine failed :unsure:
