AntarcticPilot
With a name like that and where you're based you must work for the BAS?
I did; GIS Manager.
Did you know that there are two sorts? The earlier ones, as on the eBay list in the OP, are straightforwardly current driven. 0 - 10mA, I think. Later ones look identical except for the work "Syncro" on the face and use sine and cosine drivers so the needle can be driven through 360o. Writing a driver for either would have its challenges, but they are so beautiful that it would be worth doing. I keep spares of everything, and when I run out I shall look for ways of driving the repeaters with modern instruments.
I didn't realise that. I thought the 360degree wind angle displays were all 3-wire. 3 phases at 120 degree, with a DC offset so each signal ranged 1 to 9 volts or something?
That may be how the pre-Synchro 360o ones worked - I only have a windspeed one of those (useless to me, available for postage only). The Synchro ones are, as far as I can see, all the same whether 360o or 270o. Six wires per unit, iirc - sine, cosine and illumination.
Same 3 phase principles used by Stowe wind direction displays. I managed to duplicate the function using Arduino. Just some gentle trig / maths involved![]()
