frocco
Hello all, I had a little water in my DPH-D1 drive at the end of the season. I pressure tested the drive and it passed according to the Spec in the DPH Shop
manual. I replaced all the upper and lower o-rings, shift seals as well as prop shaft seals. I pressure tested when finished and it holds 14psi for over 3 hours without losing even 1 psi.
( that´s when I ended the test) The DPH shop manual does not list a vacuum test for this drive but I did one anyways. I used the spec's suggested for the DPS-B drive
The vacuum test fails, I lose about 1 inch Hg per min. Has anyone done vacuum tests on a DPH? the only seal I did not replace was the U-joint seal which I believe is a one direction seal which might fail in a vacuum test anyway.
The 0-ring between the drive half´s was not replaced either. The o-ring I would expect to fail under pressure and vacuum if it was the issue.
Since there was water in the drive oil, I don't believe the issue was with the u-joint seal because there was no water in the u-joint bellows. I could replace it to ease my mind I guess,
but if it truly is a one way seal then it might not pas a vacuum test which would mean the drive might not be designed to pass one!
Any comments or experience Here?? Thanks in advance.
