davidpbo
Would you use your mast and boom to with an extension lashed to it to lift an outboard (44kgs.) I would use main halyard to lift point, topping lift would be attached and maybe another halyard as well. Probably use a pulley block underneath to raise and lower outboard.
The boat is a Jeanneau Tonic with a heavy cast iron keel, on its trailer which is shaped to cradle the boat, stub keel 450kgs (cc 450mm) is between two substantial metal box sections and I would pack with wood to ensure no lateral movement. Trailer is on blocks with wheels just floating. I would chock back of trailer although it shows no sign of being unstable and already has the weight of the existing outboard which would be removed first in the well.
Plan is to lift existing outboard out of well and swing it over side and lower it. Taking the weight as it is lifted off the bracket should give an indication of any problem with the arrangement I would have thought. Bottom of leg needs to clear about 8ft so lift point needs to be quite high say 14ft. Mast and boom are large section for size of boat (23.5ft) and deck stepped with a pillar underneath, fractional rig. I would take the gib halyard to the samson post as an addition the forestay.
I would probably need to leave the backstay off to give me enough room to swing the boom. I would imagine my back stay tensioner (Which is 2 double block pulleys tenioned would put a downforce on the mast equivalent to 40 +kgs.
The mast is 10m so the main halyard is probably about 30 degrees to the mast . Is the front of the boom which would probably angled up wards 30 degrees put an excessive load on the back of the mast?
My alternative would be to rig a gantry out of ladders ratchet strapped/lashed together. That leaves me with the problem of swinging the outbpoards on and off the boat.
Several blokes lifting is not an option.
