using a neutral from another battery
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
i disconnected the neutral from the house battery with some minor house stuff still switched on
expected all the house power to switch off
but as the neutral is all on a bus bar and shared with the starter battery the house stuff stayed on :unsure:
bit odd, not quite what i expected
obviously not how i would normally use the batteries
any harm in doing this long term ??
I guess you mean negatve, not neutral.
If there were no cabes on the house battery neg, then some of your "house stuff" postives must be connected to another source of 12v, starter battery possibly.
Al
That is odd - for the power to stay on there needs to be a circuit from the positive through the device to the negative of the same battery.
If the neutral is disconnected then that battery cannot provide power to anything so what you are saying is that the positive supply from you starter battery was powering the domestic circuits which would be very odd wiring indeed - unless you have a 1-both-2 switch set to both or some form of VSR to parallel the two batteries,
I think conventional wiring is to connect all negatives from all banks to a common bus and to switch individual positives.
Well done that man!
Simon has a VSR and some solar panels, i guess the solar charge has closed the VSR.
Should people learn the very basics of electrical circuits before fiddling with this sort of thing?
You must have another power source connected some where. You need both Positive +, and Negative -, to get a circuit. I would have another look.
It's worth remembering to isolate batteries before removing leads. Disconnecting under load can damage some equipment. Disconnecting under load when batteries are on charge, as would be the case in this instance, can lead to a spark and an explosion.
