jakeroyd
When singlehanded , keep an empty wide mouthed bottle handy in the cockpit for your for gentlemanly needs
wide mouthed bottle
When antifouling, start at the keel then work up and out. Took me 30 years of painted hair/hats to twig.
To cut and seal rope on board (or even at home) hold a Junior hacksaw blade in mole grips and heat on the gas hob until red hot. Cut through your rope at the desired point.
Wrap rope with scelotape first and cut in the middle.
Leave tape (now welded together) on as a whipping.
If you have no friends at the marina/boatyard, leave you headlights on when you leave the car. People will come and tell you and you'll feel popular.
Buy a cheap head-torch and replace the LEDs with red for use on a night passage. Note: this may require a different resistor.
Or coat the LED's with a few layers of red nail varnish![]()
Post on here first to say where you'll be and we'll send someone around.wot happens when your Billy no Mates
Can stain the GRPCillit Bang is great for cleaning your decks.
I have a small block attached to the chain plate at the base of the shroudHere's an unproven one, but it seems sensible to me. To avoid losing a signal halyard up the mast, thread a 2oz spherical fishing weight onto it just above the upper inglefield clip (or loop or toggle or whatever you use). This should be enough to counteract the weight of the line on the other side of the block (which normally whips it all the way up as soon as it's allowed to escape part-way) and let you jiggle it back down again, but isn't enough to make a serious wrecking ball. The bottom end of the halyard can be put through the middle of the mast cleat with something on the end to stop it pulling back through (another good thing about using inglefield clips).
The same way that you knew it was wrong! By applying a modicum of intelligence.How do you know the level was right to begin with?
Buy from a reputable source? Or maybe you have a case for just using sealed batteries.I have bought new batteries that have had seriously low levels, although still covering the plates. They have obviously never been topped up or charged while in the "Shop".
