Useful Piece of Kit
It's an older model Wempe Maritim barograph. You can still get paper roll models similar to this one: Wempe Maritim Onlineshop
My solution was my easy to build nanobaro, but now I'm simply using an app as my phone has a pressure sensor built in anyways.
I tried to build your nanobaro but my soldering skills let me down so with my tail between my legs I revered to an app.
Should be not too hard to design a board on easyeda.com then get 5 made at jlcpcb.com, 5 is minimum order, about $2 for the board then an esp wifi chip & bpm280 - all surface mounted components ready soldered on. They have arduino chips, esp chips & bmp280 available as surface mounted components. Need to do something external to get the program burnt onto the chip but could be a nice little project for someone over the winter months.
I've just ordered 5 with external esp32 & much more than just a barometer chip :cool:
Excellent. Could you figure out what one of these models would cost? One seemed to be over 1000 euro two (looking a bit like valve radios) only 168 and the dodgy looking bracket 70. My German is not well developed.
For those of baser tastes - or smaller budgets, my Alidl weather station has a barograph giving me the trend over the past 24 hours. Nowhere near as elegant, but you weep a lot less when it jumps of the wall
That isn't the one I've got, but it gives an idea. The barometer's surprising accurate, I set it when I change batteries and it's rarely more than a millibar out the next time.
How long do the batteries last ? Can you set it by inputting an altitude, or do you need to input the air pressure from a different source ?
Thanks,
Boo2
That’s exactly the model we have on Serendipity. £100 is a very good price.
Well I'm a bit embarrassed to say that I didn't even realise it was a marine one until you pointed that out. It been used at home for a few years, but now I can give it a sea trial. It's good to know I finally managed to bag a deal on eBay!
Thanks,
Boo2
Batteries last at least a year. The pressure is absolute pressure at mean sea level I think. You can adjust to give actual pressure for your height but that's pointless because as you no doubt know it's the 'Pressure Trend' which is important not the absolute pressure.
Thanks,
Boo2
I've had on of these onboard since Sept 2001 >
Batteries last for so long I don't really notice when they get changed. There an altitude settable parameter though not sure what it actually does..
Really can't see the point of having some antique mechanical expensive machine onboard when much better options are available. Unless you like looking at it rather than using it ;)
What they said above. Batteries last a year or more. The current ones may be a couple of years old, but I really can't remember when I did them.You need to reset location (for sunrise & sunset times & location), time if you're as impatient as me, otherwise it'll sort itself out from an atomic clock in Germany, and the pressure, which defaults to 1013. Any of the weather apps on my phone give the current pressure, so really not a problem.
As for reliability, I'm on my second on the boat in 15 years.
Weather reporting ship barograph. Not a thing of beauty, quite big, but works well. The diaphragm is actually in an oil bath for primary damping, the feet are on rubber pads, and in a perfect world and a much bigger vessel it ought to be suspended on springs. But it works well on a sailing boat with
Victorian pocket aneroid by B.Cooke of Hull, well known nautical instrument makers:
The usual. In this case a present from my brother in 1984; the barometer is fine but the clock has been to see a watchmaker a few times, always because the striking train gets confused.
Agree that this works well. I have some extra sensors outside and in the forward cabin. Tells me to stay in the bunk much longer.!
Only issue is that the frog requires some batteries.
You get a lot further than most. Usual life cycle of an Arduino is purchase->excitement->flashing light->draw->occasional guilt. I have a bunch of project that I haven't even started as have been working in embedded systems for the last few years and it's all a bit busman's holiday.
