sailaboutvic
The Victron BMS will do all of that without using external relays Vic: https://www.victronenergy.com/upload/documents/Manual-BMS-12-200-EN-NL-FR-ES-DE.pdf
Thank for that Paul but it looks like it more suited for drop in rather then cells .The Victron BMS will do all of that without using external relays Vic: https://www.victronenergy.com/upload/documents/Manual-BMS-12-200-EN-NL-FR-ES-DE.pdf
Mine BMS is on the way , what I like about the 123smart BMS is you can see what each cells doing and different in voltage, you only need one BMS for a 2P4S there's I still farting about to wire it up but in the end I think it's worth it to be able to see what's going on and have controls over the relays , you also got current reading of what's going in and out and a combination of both too , it's not cheap at €350 but hey after reminding me earlier that I have the forum record for destroying Trojan
