usb wiring for nmea
1611
20 Feb 2006
Liveaboard
I am trying to patch into my existing nmea output to provide gps to my laptop. I have identified the nmea+ and nmea - from my gps but do not know which of the different wires inside the cable terminating in a usb male to connect to. Is it just the two or do I need to connect others. Help appreciated.
Agreed. Mine cost about £30 but I'm sure you can get it for less than that if you shop around. After that it's just a question of soldering the GPS leads to the correct pins.
There are two things to look at here.
NMEA is basically the language that is spoken i.e. what's contained in the sentences.
USB / RS232 is the way that NMEA is spoken and the two use not only different physical hardware (i.e. the connectors are different) but also a different method to communicate.
So as previously mentioned - you will need a USB to RS232 converter
Buy a usb to seriell converter on Ebay in Hong Kong. The converter is abot €1 and shipping € 6. Was a pretty good deal and its working well.
You should use a proper converter (Serial to USB). It's not just a question of pins, there is also the difference in volts used for the signal. USB use 5 volts and most NMEA (RS232) use anything from 5 to 12 volts and most likely 12 volts. Most PCs are optically isolated and it it may be OK but ................ best not to risk damaging your PC and use a converter.
www.jgtech.co.uk have them on their web site or search e-bay as previously recommended.
Alan.
