Norman_E
Its getting odder, because Gigabyte suggested flashing the Bios to the latest version, which I did, with not much improvement though the dongle did find the satellelites without getting a fix from them. I the put the dongle on to a laptop, where it had worked perfectly yesterday, and it took a long time to get a fix, but eventually worked, but became erratic, losing its fix then regaining it. I tried a firmware update, but it did not work. I have ordered different make of dongle to see if it is better, as I now think that the dongle may actually be the source of the problem. I have no problems using Windows 10 which I have found to be stable, and less of a resource hog than most previous versions of Windows.
The Brix 3150 is now going to be gifted to SWMBO to replace the old PC she only really uses for the internet, partly because it runs on 19 volts and needs me to put a buck converter on to the boat to run it. The older Brix 2807 and 1900 models have both USB2 and USB3 ports, and crucially run from a 12 volt 2.5 amp supply, which I already have on the boat. I may buy one.
