URGENT ! HOW TO STOP A DIESEL ENGINE ?!
I had the same with a Beta 10, in my case the solenoid itself had loosened on it's mounting so it was activating but not enough to stop the engine...
Had similar but the slight loosening meant the earth return wasn't working properly - clean up etc and all was good.
ps I also have a Beta 25 but didn't know there was a manual stop lever - I'll investigate when I visit next.
Here you go - Beta (all models) manual shows what it looks like, and text at bottom of the page indicates where it is (fwd end of motor, mid-level, starboard, unless you've got 75hp or upwards):
OM 221 20031 HE REV30 0322
Source of problem found - the stop button to solenoid connection in the multi-wire connector box behind the engine had become corroded - now all spades etc scraped clean and coated with vaseline, and the loose rubber boot covering now properly sealed with tape.
Why marine diesels have wiring connectors etc in vulnerable-to-wet and hideously inaccessible places is beyond me.
Useful thread. Thanks all. Will find my stop lever on next visit to the boat..... (although my last thread on this subject was trying to get my beta to start having dislodged one of those multi-plugs.) :)
This is useful of course. But if a diesel runs away the stop lever won’t work. It stops the diesel fuel but when it runs away it is burning its own oil.
Because a decent size diesel will ingest anything near its air intake causing damage or injury.
If you have a tiny engine you may get lucky and it may work. But why learn bad practice? If an engine runs away you need to react quickly.
CO2 fire extinguisher every time.
Oh really...!?
You have lost the ignition feed to the stop solenoid. Ignition switch on?
I bet you have stood on the wiring loom and lost the connection at the daft multiplug in the loom near the engine.
Did that today, fault finding. At least it's easy to get at for me, as my access is from the rear of the engine, which makes impellor and fan belt maintenance interesting. New filter, plus a bulb pump to simplify bleeding fixed my problem. Two oil filters on board, but no fuel filters. o_O
Don’t know unless you answer the question.
You asked me if I doubted it. Well it would depend upon what it was. Then I could tell you if I doubted it or not. But let me say that the last 8 reasonably sized diesels that I was responsible for (driving platform and O&G terminal standby generators and fire fighting pumps) all had simple inlet closure devices fitted as standard and expense was of little consideration when compared to safety and reliability. A days shutdown would cost in excess of $10 million! I don't doubt that CO2 injected into and flooding an engine in sufficient volume to stop ignition until the engine was at stand still would work. But it brings issues with it including a very high risk to personnel using it in confined areas. But hey you beat the drum for whatever, who gives one?
I've always fancied a butterfly valve on my diesel so that I could be sure of shutting it down quickly were a runaway to occur, but have never gotten around to it. Realistically it's another expense, we can't prepare against every eventuality and the vast majority of leisure boats (I bet over 99%) don't have them.
In the absence of a butterfly valve on the air intake, and in the sudden and unexpected case of diesel runaway, a CO2 fire extinguisher seems like a very good solution - it should be effective at stopping the engine, at least.
When diesel engines are used anywhere that there is a danger from inflammable gases, for example in the oil and gas industry, the engines are required to be fitted with Chalwin valves. In the event of gas entering the engine air intake, causing the engine to race out of control, the valve automatically shuts off the air intake, stopping the engine. So not only does it work, it is a legal requirement.
Wrong about what ?
I said that impromptu devices to block the air intakes of Diesel engines was a bad idea.
Because the facts wouldn’t be known and injury or damage could occur.
You made a derogatory response to that.
I questioned that.
You tried to prove me wrong by saying that it was possible to stop a Diesel engine with a custom built throttle.
Just what has that got to do with my statement?
