Upsidedownamaran.
capnsensible
15 Mar 2007
Atlantic
Weather in the Canaries recently has been a tad windy and a bit wet on the Eastern Islands. The cause of this has been ablarge depression out in the Atlantic. Happens once or twice a year and brings the wind from the south west. Not so bad, but the swell with it can be dangerous. Two boats here didn't move in time. Links here that should be in english, but easily translated.
Sad for those cruisers.
Declarada la prealerta por contaminación marina por el vuelco de otro barco en el sur de Lanzarote
El fuerte oleaje y el viento dejan a la deriva un velero en Playa Blanca
The second one ran aground on the breakwater at Playa Dorada. Looks metal so may have been saved.
The catamaran as you can see is wasted. Prout, I think. On the starboard hull, on the longitudinal keel, there is a deep vertical slit almost as if it ran over oits anchor cable and rubbed a groove. I wonder if this caused it to kinda trip over the cable in the big swell?
capnsensible
15 Mar 2007
Atlantic
Does it break in there? I can’t imagine a swell capsizing a Prout. But then, I guess they didn’t either, and there lies the problem.
Yeah that's it. I took some photos yesterday but they really don't show the scale of the problem. Happens a couple of times a year. An opportunity of mine has a laid mooring very near by. Two one ton concrete blocks. However he is off on another yacht for a 7 month Carib cruise. Knowing the winter weather, he took his yacht, Sandler 34, around to Puerto Calero for the duration.
As mentioned, I wonder if somehow, the anchor chain tripped it somehow?
I've heard, but not confirmed, the metal boat was recovered OK.
Trident
21 Sep 2012
Somewhere, nowhere
A news source on the island said there were gusts of 70 mph and 4 m waves at one stage and a fellow Prout owner in the marina next to this mentioned on the owners forum that it was anchored too close to shore so ended up in breaking waves before coming loose... No idea if either is correct
capnsensible
15 Mar 2007
Atlantic
I live up the road. Locally, the wind wasn't anything near that. Breaking waves correct though. (y)
wingcommander
25 Jul 2013
One big advantage of a shallow keel or multi hull is the ability to get inshore closer in a busy anchorage. Obviously one of the biggest disadvantage is when it blows up like this. Must admit my very first overnight on the hook I realised I was in too shallow water , as I had a very rolly night compared to a fellow sailer who had quite a relaxed night in several mtrs deeper water .. lesson learned.
Chiara’s slave
14 Apr 2022
Western Solent
It’s what the surfers call a reef break here. But it comes to much the same thing, just not quite where you expect it. Even us multis are better off in water deep enough for any expected waves not to be even thinking of breaking. They get all steep and uncomfortable, even if they don’t break.
