Concerto
When I changed the stanchions on my Fulmar, I raised them from 24" to 27". It has made working on the boat a lot safer. Solid rails would certainly be wise from the stern to the front of the cockpit as it makes leaning against them firmer. Personally I would fit side gates at the maximum beam point as stepping over 27" is difficult for those with short legs. Using wire in the sections from the bow to the front of the cockpit would be my choice. Presumably you will still have a lower wire fitted. The final point you should check is will a solid rail affect any feature like winch handles or hatches.
