Update on Solo Dinghy
Lakesailor
15 Feb 2005
Near Here
What I bought from Searush.
I knew it had some leaks when we agreed the deal and this is a little update on what I found and what I've done so far.
Steve told me that the chine had a crack and that the buoyancy tank would get a bit awash when sailing. I was surprised to find the cockpit was also about 3" deep in water by the time I got back to shore. Steve thought this was due to the cockpit sole/buoyancy tanks joint. Someone had blathered the joint in a rock-hard repair filler already, but cracks had appeared.
You can see the filler around the cockpit sole edges. The toe-board on the centreboard case has cracked at the after starboard corner as well.
The tiller hole and transom flaps have some missing coatings and the balsa is beginning to rot a bit.
The main problems were the crack and the hole (plus three smaller holes)
The chine crack had been repaired already. I ground it out and laid some mat and resin in. Then some grp filler paste (with chopped fibres in it) and some gelcoat on top.
Ground out
The same for the hole and for the other three smaller holes except I didn't need the mat for that. The filler paste was fine.
You have to be careful not to make the repair too strong. If the chine ends up rock hard it won't flex as it is supposed to. The GRP is very thin. If you press around the hull where it's sound there is lots of movement. If you make a "hard spot" it'll do more harm than good.
This is the "S" shaped hole before and after after grinding, matting filling and gel-coating. Yes it's rough, but this is before finishing off.
The filler on the cockpit sole was a nightmare to chip off. Took about 4 hrs.
Once removed I cleared out the slot and used an air-line to dry it. It seems as though there is a bead of resin in the bottom of the slot. In fact looking at the Solo web site it seems this cockpit sole is a liner installed after the buoyancy tanks have been bonded to the hull. So it may be that the water is not coming from this joint. Anyway I filled it with Sabatack750XL which is a marine structural sealer.
I epoxied the centreboard and varnished it with a semigloss Epifanes as the boat will be afloat for a couple of months at a time.
I also stripped and revarnished the mainsheet track mount which carries the running rigging line cleats and supports the centreboard case.
This is the mainsheet track re-fitted.
On the transom I dug out the soft balsa and used the grp filler paste (with fibres) to fill and seal the hole.
The hull/deck joint had quite a lot of missing filler so I used the Sabatack to bond that back in place as well.
So this is where I stand at the moment.
I think the water is leaking into the cockpit through the self-bailers. I am making a launch trolley at the moment so as soon as that is ready I'll put the boat up on it and can test the bailers. If needs be I'll just seal them up for the moment.
I have to step the mast and sort out the running rigging (Kicker, outhaul and cunningham) which all have double ended lines.
I've already replaced the wire in the kicker winch.
If any Solo sailors know if there is a protocol for arranging them (in the cleats) I'd be pleased to know.
Then I just need to complete a compounding of the blue gel coat on the deck.
Aiming for next week as the forecast (according to Simon) is a lot better.
Steve's Last Sail
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
Wow, that's already looking so much better. The re-varnished woodwork really kicks it off.
Mind you I'm not sure that my technique of going ashore to empty her out once an hour isn't more efficient. It only takes 5 mins to empty her once an hour.
4 hours work on just cleaning off the joints = 48 hours sailing! :D
Seriously tho, good work Phil, nice to see the old girl getting the attention she deserves, she will pay you back with many hours of happy sailing.
DanTribe
8 Jan 2002
Essex
Good work so far. Hours of Occupational Therapy available there.
I found a good way to check for leaks in buoyancy tanks. Get a push fit overflow pipe connector and fit to a spare hatch cover, this will take an Avon dinghy bellows which can then be used to gently pressurise the tank. Brush on soapy water to seams and look for bubbles.
Searush
14 Oct 2006
back2bikes.org.uk
Left in the boat house, it would sink!
Yeah, but only once, until you refloated her! :D
I was only teasing. My style of sailing her as a cheapo fun boat was just so different I couldn't resist a tease! :p
I'm actually delighted to see her starting to glow with pride after such a long period of sustained abuse by former owners. Thank you again, it's so nice to be kept in touch. Especially as I haven't even had a chance to get the replacement GP14 out on the driveway for a test rig to see if she's all OK. :eek:
Edit; I think most of the hull water comes up the centreboard & that got much worse after the gasket seal underneath split & fell off.
Lakesailor
15 Feb 2005
Near Here
I looked at that but the screws holding the brass strip on are so far gone it's a drill out, fill the hole, and start again job.
I'll see how much slops in and decide on that for next winter.
