nathanlee
Afternoon (and what a good one it is!)
I've got a wee problem. The main halyard block at the top of my mast seems to have broken in some sort of nasty way. I had an absolute nightmare trying to get the main down earlier.
I need to get up the mast asap, the only problem is...
I'm single handed (as in crew, not limbs)
The broken blocked main halyard is the only one I have with rope thick and new enough to trust with my weight. The genoa halyard might work, but it's quite thin (8mm I think). I've climbed on 7mm rope before, but that was brand new. The only other halyard I have needs to come down really, it's very old and knackered and was probably used for the spinny, which I don't have. There's no way I would put my weight on it, so we can ignore that one.
The kit I have available is a climbing harness, 1 pretzl ascender, spare chord which i could use to makes prusiks if needed. A couple of crabs and a figure of 8 belay device.
The only way I can think of, born from years of climbing, is to prusik up the doubled over halyard on the broken block (risky in itself), but then that leaves me with my weight on the thing so I can't change the block over.
Suggestions are welcome.
I'm on the Deben too, so no bridges seem to be near.
