chal
This is the battery switching setup in a new-to-me Westerly boat. I haven't seen wiring like this before. I know it was professionally installed when the new engine was installed c2006. It all seems well done and in good condition. There are two batteries, which I'm about to replace, one connected to each isolator.As you can see, both the starter motor and the house circuit are connected to one of the switches, so there is no way of connecting one without the other. You can have one or other batteries, or both, but always with everything or nothing running. So far as I know the previous owner just turned both switches on and that was it, in which case there might as well be only a single switch.
Mostly what the batteries do is start the engine. The boat has very little in the way of electrical systems - a few lights and a water pump - and lives in a marina with shore power so the batteries can be kept well-charged.
My plan is to replace the batteries with two new AGM leisure batteries as these are leak proof and maintenance free and claim to be equally good for starting and general power supply. Is there any benefit to treating them as separate batteries and trying to alternate which one gets used for what? I could change the wiring so one became the house battery and the other the starting battery, but given the way they will be used, I doubt if there would be much benefit. The existing switches are the type you have to operate with a key, which I'm not particularly keen on. I own a new, expensive rotary on-off switch and am inclined to use that as a replacement for them. It would make everything nice and simple, and make it easy to charge them both at the same time. Is there any obvious drawback to doing that?
