doug748
What sort of thing do I have to be certain about? You have exactly the same information as me, and nothing in my advice (or any others') is unreasonable based on what is available.
Guess you have never renovated either type of boat, but you might like to consider the difference in volume and range of gear that goes up according to the size of boat. Some simple differences. If the inboard is past it the 22 can use an outboard as the bracket in the video suggests. The mast of the 22 can be raised manually (even if those idiots on the video cocked it up) whereas the bigger boat will need a crane. Sail area is probably 50% greater, as will be the cost of replacements. Need I go on?
The consistent advice from a number of people is the same. Avoid this type of project, particularly as he is a novice, and if he does want to buy a boat spend the money on one that works.
Of course he does not have to take that advice, and one can see why he might find it attractive. Equally I can see why the yard owner is anxious to get a new owner responsible for it rather than having to dispose of it himself.
10 years ago it might have been a good deal to take on such a boat, particularly if experienced but things have changed somewhat.
The second remark was directed at the OP, that is why it was separated by six blank lines.
As in - If you take this on you have to be "very certain of your ground":
*You have to be aware of all the things that have been said - most ring true
*It's a steady sailor and will never be worth much
*The sails have to be usable and the engine worth a punt
*A sensible offer may be in the couple of hundred range any more is difficult to justify even though the trailer is potentially worth a lot.
*You have to be really sure you want a project for it's own sake, not because you fancy the idea or just because it is on the doorstep. You have to have some sort of practical ability and be willing.
Of course to some people it is obviously better to get a super boat for £2,000 rather than £200 but only people that have the option. If the OP has the option then fine, he may not. Watch the video.
The increased cost in putting things right on a 26ft boat over a 22ft boat is mostly trivial.
So just admit that you did not read or understand my opening gambit:
"I can't disagree much with anything that has been said."
You are in danger of making yourself look like a right old tator, again
