AntarcticPilot
Alternatively taste the bilge water and then taste the sea.
If it's potentially got hydraulic fluid in it, I'd rather not taste it - some hydraulic fluids are pretty nasty.
No, thank goodness!You've never had to syphon diesel offshore in an emergency then?
No, thank goodness!
But I was more worried that some hydraulic fluids are actually poisonous, not just evil-tasting. For example, apparently they MAY contain organophosphates, and I certainly don't want them in my mouth.
You wouldn't be drinking pints of bilge water unless you got a taste for it. Just licking the tip of a finger...
This is what I've been doing, before spitting it out PDQ. Considering how grimy the bilges are, I really don't want to be letting any more of that crud in my mouth than I really need to.
If closing off the water tanks doesn't provide any clues, I'll try the silver nitrate idea.
I'm pretty certain the gland and that part of the boat are not involved as they have "basins" which would be filling with water before they drained into the other parts of the bilge. So far, these hollows have remained dry.
I'm starting to wonder whether the leak may be from the fresh water system. I can't locate it, but this was my original thought, and if the water could taste salty due to bilge dirt and remaining salt, that would explain the taste. I really can't find any external sources of water. Ideally, I'd like to empty out the water tanks and see what happens overnight, but we need the water to drink at the moment! I'll close of the tanks and see what happens tonight, though. Worth a shot, I guess!
Use an oil extraction pump. The type with the bottle is best. The hose is very small & so does not let a lot of water run back past the strum box like a larger pump.Thanks all for the advice.
I will try to get the bilges dry, though it really isn't easy. It's a relatively flat, wide bilge, so getting the water out of the bottom couple of cm is nigh on impossible. But I'll get the hand held bilge pump on it and see what I can do.
Then I shall spread some talcum powder and make a right mess!
Another mad suggestion!
If the grounding plate is rusty or corroded water could be getting in the hull plate joint. The keel bolts would be tight but water coming in via the bad fit
I turned off the taps to the tanks, turned off the fresh water pump and left the galley taps open to remove the pressure, and unfortunately we still gained a decent amount of water.
Well, last night didn't work! I turned off the taps to the tanks, turned off the fresh water pump and left the galley taps open to remove the pressure from the system, and unfortunately we still gained a decent amount of water. If it is a fresh water leak, then it'll be coming from the bottom side of our new plastic tank we fitted at the beginning of the season.
I really need to ascertain whether the water is fresh or salty.
I'm also going to try emptying out the bilges as best as I can. I have a hand held bilge pump, which is pretty good at getting shallow water out, so that'll be the next step.
Joy!
This is actually something I had considered. Our grounding plate is pretty rusty (and will probably be getting some professional TLC, once we're back in the UK), but I don't see how that could be causing the leak. As far as I can tell, the grounding plate slots into a recess in the GRP hull. The only actual holes in the GRP are for the keel/grounding plate bolts and the keel box itself, which is above the waterline. Unless someone can provide some info that I'm missing, I just can't see where water could be getting in due to grounding plate rust.
