Unexpected Consequences
john_morris_uk
3 Jul 2002
At sea somewhere.
A salutary story.
One day left of an extended voyage and our Whisperpower Piccolo Generator suddenly stopped. It was brand-new and had only been in use for a few months.
0F634EA5-88E5-4165-A985-B5663401BD35.jpegThe Piccolo generators have a diesel engine with a fixed magnet alternator that produces 400+ volts AC that goes to a device called a PMG that controls the generator and also converts the 400+V to 230 V pure 50hz sine wave. When it stopped, the fault came up in the panel as PMG failure.
So I assumed the failure was fatal and a new PMG electronics magic box would be required under warranty.
Emailing the supplier produced no reply. (I’m still waiting two weeks later!) Consulting the local agents and they consulted the manufacturers who said that there were five faults that could produce that warning light indicator. The only one we could reasonably be expected to check ourselves was a fuel failure. Basically, if there is a fuel failure the engine slows down the 400 V goes out of range for the PMG and the PMG shuts down the engine and shows PMG failure as the fault…
We checked through the fuel line and even took the CAV filter out to see if there was a problem. The filter was immaculately clean (it should have been with a brand new fuel tank and only clean fuel for the previous few months ) and we could find no fault in the fuel line at all. Fuel was getting through to the injector pump when we pumped the hand pump (that I’d fitted on the CAV filter to help with the bleeding process) and it was bled perfectly.
The symptom now became that the generator would start and run for a few seconds and then shut itself down with the fault coming up as PMG failure. A multimeter on the stop solenoid show that the PMG was only demanding that the generator stopped when the revs died away. Fuel was obviously not getting through in sufficient quantity, and although there was no sign of contamination or blockage in the coarse filter the only filter left was the fine filter. We reluctantly agreed that the only course of action was to replace this in the hope that there was some sort of blockage in there. However as I groped around the side of the generator I discovered the real fault. When we had been doing initial running checks on the engine a few weeks previously, my friend and colleague had noticed that the exhaust was dripping slightly at one of the junctions. Specifically the exit from the generator itself where the hose connected to the water trap and from there to the water separator before separating water (being discharged below the waterline) and fumes (being discharged above waterline). It’s a slightly complex exhaust system with a lot of connections. Obviously where the hottest connection was, adjacent to the engine, the hose had settled and allowed a drip of seawater to appear from time to time. The T clamp was tightened and the drip stopped and we thought nothing more of it. What we hadn’t noticed was that the drip had gone onto a connector to the electric fuel pump for the generator which was hidden and almost out of sight. The connection was corroded and produced an intermittent fuel pump.
New connections made and subsequently sprayed with anticorrosion spray and the generator is back up and running again perfectly.
So a fault that appeared as PMG failure was actually an electrical fault to the electric fuel pump of the generator causing it to slow and that caused the PMG to stop the generator and signal that it was faulty. A lesson learned.
C08
8 Feb 2013
Interesting - it just shows that methodically going through the system in detail can reveal what are initially thought to be terminal faults can actiually be very minor issues and cheap to fix.
vas
21 Jun 2011
Volos-Athens
Interesting - it just shows that methodically going through the system in detail can reveal what are initially thought to be terminal faults can actually be very minor issues and cheap to fix.
and shows how annoying poor are the messages provided by the manufacturer in terms of errors.
would be possible to send an error on low RPM, closing rather than the generic conversion failure.
Same thing happens with cars coming up with fancy obd messages that are plain wrong or too generic send you searching something completely irrelevant!
V.
PS. well done to OP!
[2574]
29 Nov 2002
Good logical fault finding John, as a bit of advice I’d add that you ought to check if your instant bbq (under the paddle) isn’t also full of water otherwise there could be a disappointing end to a planned shoreside dinner party…
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
I've had this problem several times, ie the unit showing a PMG failure, when it was some other cause, most recently the fuel pump failed, and an impeller failure, although that also showed a high exhaust temperature alarm.
The unit was purchased in September 2021, so not 2years old yet, and I can't say I'm impressed by the reliability.
The first unit failed to start on installation. It wouldn't turnover, failing to go over top dead centre. That was promptly replace under garentee, but cost me an installation and removal, plus return shipping, a weeks extra Marina fees, plus sailng time.
The PMG failure light came on with 2 different silly electrical faults, loose connections, which were easily traced.
I've now had a fuel pump failure, which was hard to find because the generator ran for about 25mins then stopped with a PMG failure. Turned out that the generator was beening fed by gravity. The fuel tank was full proving a head of about 1m.
Now the impeller has failed. The rubber blades not being bonded to the core properly. Further complicated by the spare I have doesn’t fit, dispite having the correct part number.
Not impressed.
gregcope
21 Aug 2004
@john_morris_uk Part way through the story when I saw the collection of lower locker contents I was hoping the cricket bat was going to be used as a precision instrument.
Nice find/debugging. I have had similar issues with a leak from an exhaust. Took ages to find as it was intermittent, when the engine was warm all you saw was damp rust. Damaged the engine mounts which also necessitating replacing the cutlass bearing and shaft in due course ...
I know its due to costs, but it feels cheap to often not protect parts that might get splashed and cause issues.
@vas Mercedes cars are famous in the UK for often throwing a load of odd error messages. If the car batteries are more than a few years old you will be asked to replace them which magically fixes the issues. A low voltage warning would be much more informative ...
  • Like
Reactions: vas
C08
8 Feb 2013
Yes diagnosis can be extremely difficult and confusing. My current problem with my outboard locking in gear I am now certain that the problem is actually a sticking carburrettor cable which is not allowing the engine to slow down enough to go out of gear. So the gear locking only a sympton of the problem not the actual problem. Thanks to QBhuoy for pointing me in the right direction.
