rotrax
As an admirer of Sturmey Archer gears, Singer Sewing machines, Bale knotters, Concord and beam engines I am always amazed and impressed at the simplicity, reliability and power of Seagull outboards.
They are brilliant bits of engineering - astonishing - amazing - wonderful.
I have had an old two stroke in my garage for years - I pulled it out, put some fresh fuel in and fired it up.
It did leave a lot of gunge in the test tank though.
http://www.keepturningleft.co.uk/2011-video-logs/ktl-vlog-128-starting-the-seagull/
I had put it in the garage because I used it on the broads for one trip - but I was so worried about the amount of oil and petrol it threw around a sensitive environment that I went out and bought a Honda 2.3 hp four stroke. Great little engine by the way. Sold that with the seafarer trailer sailor I was using at the time.
As a temproary engine for my current MD1 related excitements Al (of Al and Stewie fame) loaned me a four hp seagull as a standby in case the beast gear box finally gave up.
I started it up and it ran okay on the back of the slug - I even sort of liked the noise of it
but Nora!
Seagulls are dirty things.....
I really felt so bad about the thing that I now beleive that they should not be used anywhere outside of a test tank.
I do hope people will not take this too much to heart or abuse me for what is a personal decision
http://www.keepturningleft.co.uk/2011-video-logs/ktl-vlog-137-the-unethical-use-of-a-seagull/
Dylan
Hi Dylan, I had a 40 plus for some years and used it to push a big dinghy on the canals and Thames. I got hold of what was at the time leading edge motorcycle racing synthetic two stroke oil-Shell if IIRC. With this mixed at 50:1 no smoke to worry about. Also smelt like a scrambles race meeting from behind! I also adjusted the carb. needle to make it a little leaner when on the canal as the speeds were so low.When tickling the carb just get the fuel level up to the outlet hole and no more-hold a rag on the carb to catch any drips if you can. I have a couple of Yamaha outboards. Recomended oil/fuel ratio 100:1 on normal marine two stroke oil. Modern synthetic oil at 50:1-give it a try!
