MarieK
Daka can you point me in the direction of solar cockpit lights please?
Mr Astronomers rather worryingsolitary hobby does not have a detrimental effect on any other living soul
Just curious, why?
I would think that while swimming towards the boat, deeper lights should be less annoying to the swimmer eyes.
Besides, in the higher position, wouldn't they be covered by the swim platform whet it's lowered?
Aha, I see. That reason alone is good enough.on both the Sq58 and 78 it allows the lights to be above the "rudder board" which is better for maintenance.
And I don't disagree also with oldgit, light pollution is ...ermm... pollution (as you also agreed in your post #13), whilst the astronomer doesn't harm anyone (eventually, restricting the freedom to pollute is because of other pollution consequences, not because of the astronomer's hobby). But in this respect, shouldn't we ban all pleasure boats, before caring about u/w lights? Sailboats included, btw. They also contribute to pollution, in more than one respect - though obviously less than MoBos, AOTBE.
Change of plan, I'm going to have these on the bathing platform and radar arch :- http://cgi.ebay.co.uk/BRAND-NEW-MUS...tem&pt=UK_Garden_Lighting&hash=item255a527c0b
My point exactly.What next ?
DDT the rain forest to reduce pollution from Fireflys.
JFM
I have tried to do what you suggest the back of the light is a 32mm thread with a big nut on it and a load of sikaflex. to attact the wirte to the back of the light I had 2 ideas.
plan a, drill into the nut 3mm and tap it then screw a wire bond on to it. cant do this as the metal very strong and the angle of drilling is close to parts so not a lot of room.
Plan b, was to see if solder would stick to a rough area after I rub it with a file.
neither have worked so I have 2 more plans, to attach a jubille clip around the nut tightly and attach a wire to that, or use a crocadile clip and clamp it to the nut.
would either of those ideas work or cause a problem?
As an aside, I can't get my head around the usefulness/pollution debate.
I mean, obviously Searush is correct when he says that u/w light are rather a bling than an essential equipment. But I'm sure that none of us, if forced by a restricted budget to choose between either u/w lights or say safety jackets, would go for the latter!
Whoops, I just realised the typo.But I'm sure that none of us, if forced by a restricted budget to choose between either u/w lights or say safety jackets, would go for the latter!
why should the wishes of Mr A (the amateur astronomer) prevail over the wishes of Mr B (the boater who wants a party night with his friends swimming in a turquoise-lit sea, on the same evening)? Clearly it isn't possible for both Mr A and Mr B to be happy that evening, as their wishes/happiness conflict.
Au contraire, if Mr B - whose boat has a high OB quotient - isn't prepared to turn the lights up to 11 then Mr A isn't going to be able to get such an eyeful. Unless telescope technology has moved on from my day.
So, lights on: everyone very happy
All street lighting and suspect stadium lighting too,has now to meet some very strict regulations regarding the amount and type of light given out,in order to minimise its affects on the surrounding area and not waste energy.
