Neeves
Skippers rules.
(S)he who blocks it has to unblock it.
Ours is similar (but not sexist)
"anyone blocking the toilet is promoted to Head Cleaner"
Jonathan
Skippers rules.
No paper in ours. Special bag.
I think they are misnamed, surely a fresh Richard III would take months to be broken down into harmless, inoffensive compost? A few weeks' cruising with a few crew could easily generate 100 kilos of human poop.I haven't read all the posts but it males compost toilets ;lok pretty good sureky?
I think a better name might be, 'sailing sround with a box of earth and carp on board until you can dispose of it'.
Unless I am missing something?
No1s and no 2s only in our loo.Paper and any other man made stuff into nappy bags provided thank you.
Which is it, your toilet is hard to block, or you have unreasonable rules to avoid blockages? My well maintained Jabsco doesn't block and we use Charmin quilted paper.Its why I use cheap biodegradable paper that falls apart in water ... a
Also a general rule passed on to those who sail on my tub :
Wipe - Pump - Wipe - Pump ....... to avoid building up a mass of 'paper' to clear ...
But of course I do have a Royal Baby Blake ... pretty hard to block one of those !!
My point was that a recommendation from someone who doesn't really use the item the way it's designed isn't really a recommendation, quite the opposite. Most issues with Jabsco are down to scaling in the pipe which is easily sorted by maintenance. You're quite free to have any crazy bathroom routines you like as skipper of your own boat, but don't suggest that your toilet is better when you're not actually using it!
I didn't say you were the only one with a crazy procedure for using a simple device. You were, however, someone advocating for your model of loo with the implication it's less likely to block. I was simply pointing out that a loo that's never given the chance to block is a poor example. I then highlighted that Jabsco loos which are used in the normal way without such procedures cope absolutely fine. The conclusion from this limited dataset is that Jabsco is the superior toilet, and that it gives confidence to owners. Your anecdote would suggest you lack confidence in your toilet's abilities to clear waste.
I didn't say that at all, I pointed out that your assumption that the unit is superior is flawed because you don't use it properly. A good unit wouldn't need to be played safe, and as I said, I prefer maintenance over playing it safe and teaching gownups how to use a loo.Your OPINION ...... and that's all it is.
What a crazy assumption you make ... that playing safe means the unit is not good ..... WOW !!
I'll leave you with your misguided 2 + 2 = 5 opinion.
Obviously you haven't had any experience with compost toilets ? (Maybe do some research before commenting)
"Composting heads offer several big advantages for sailors: They require no through-hull fittings, no plumbing, and no separate holding tank. They have few moving parts. The solids are reduced fairly quickly, and take up less space than the mixed sewage, urine, and flush-water of a holding tank. On the negative side, the toilets themselves take up more space in the head compartment, they require a through-deck fitting and vent, and they need a constant supply of electricity (in very small to moderate amounts) to perform at their best. "
Composting Marine Heads - Practical Sailor
Yes I think you are missing something.
