Uk trailers in Spain
wallacebob
28 Dec 2008
Forth
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
For info: it is pretty much the same in France with a couple of exceptions.
1. The unbraked limit with the same registration as the towing vehicle, unlike everywhere else in Europe, is 500 kg. I brought a trailer I built myself to France but had to sell it, as the total weight of trailer plus load (car) was 640 kg. It would have been impossible to register.
2. I believe that trailers do not need a CT (MOT) test assuming they hold a certificate of conformity. They do need to have their own registration and plate and to have insurance.
Refueler
13 Sep 2008
Far away from hooray henrys
In Latvia ... we can tow a UK trailer here without plates - 750kg max load if unbraked ..... BUT there is a time limit of x days if intended to stay here and not returning to UK. On or before that limit - it must be presented for CSDD inspection and registration.
They don't like 'own built' trailers unless from a reputable kit ... but they accept reluctantly !!
There's a 'quirk' about this .... if the trailer has own registration - then it needs own insurance - the car policy does not cover it.... as CSDD told me. But if its not registered and towed as a UK 'visitor' then car policy does cover ...
Personally I would insure separately if visiting here ... Traffic Police can be somewhat 'troublesome' ...
DownWest
25 Dec 2007
S.W. France
Also in France:
In 2012, they changed the regs. So, effectively, you can no longer build your own. Previously, under the 500kg limit, it was a free for all. Some of the really frightening ones at the local B&Q probably weighed over 500kg with no load..
As a one time pro trailer builder, I find it a bit frustrating, as I need one in the 500 to 750 kg range. If it was under, I could fake the age a bit. Currently looking for 'doer upper' that I can adapt to the non standard launch system.
You can build your own, but, unlike in the UK, it has to be homologated. Which is OK if you are a series builder, but prohibititvely expensive for a 'one off'.
UK gets round it with a one off cert. Slightly more careful MOT, like kit cars need to be reged.
