Two echo sounders
bob26
21 Dec 2002
Sussex-by-the-sea
www.tridentlottie.com
I am mounting a NASA Duet joint speed and log in the cockpit. I understand you can't use repeaters with these so I will have no indication of depth at the chart table. I have several spare echo sounders which would be fine for this but is it possible either:
1. To run two sounder heads off one transducer at the same time? Or
2. Have two echo sounder transducers working at the same time?
3. Have some kind of switch over between deck and cabin instruments?
VicMallows
25 Nov 2003
Emsworth, Chichester Hbr, UK
You certainly can't use 2 sounders with 1 transducer. (well, you could, but getting highly technical).
However I'm sure you'll be OK with two seperate sounders/transducers as long as they are sufficiently apart (e.g. fore & aft) ...........unless you are travelling at supersonic speeds, that is.
Vic
VicMallows
25 Nov 2003
Re: Getting technical
If you choose to go the 'switch' route, try to make a reasonable coaxial switch (Maplin probably have one off the shelf).... though at the frequency we're talking about (150kHz) I doubt if it will cause much trouble. You must maintain the overall length of coax the same because most transducers are tuned as an 'item'. (lazy engineering, IMHO).
Vic
gjgm
14 Mar 2002
London
well I have 2 transducers, and they are so close they touch.. but neither interferes with the other. I d guess the frequency is as dependent as the distance apart.
