ari
Firstly, ignore any advice about leaving the wheel amidships and just using the engines. Works for shaft drive but sterndrive just doesn't have the leverage (as props are effectively behind the boat) so it will work to some extent, but you really need to use the wheel as well to direct the thrust.
Now imagine you did have the wheel amidships and went astern on the port engine. Because it's pulling the port side of the boat more as is on that side, it will gradually swing the bow to port.
Now imagine putting the helm down to port as well, now you have some thrust to the side at the stern pulling the boat to port from the propellor.
So both in conjunction will gently crab the boat to port as it goes backwards. Find the right amount of helm (and it will vary depending on things like wind) and the boat will remain parallel to the berth but easing to port as you move backwards.
You can also slow things down by shifting to neutral , putting the helm down to starboard and giving a nudge ahead on the starboard engine (same sort of thing applies, the fact that it's the starboard engine will 'lever' the bow to port, the fact that the helm is down to starboard means that the thrust from the outdrive will push the stern to port).
Bear in mind we're not talking full lock here, nothing like. You need to experiment to find out how much.
