Genoa
... I was considering posting this on the dark side, as I have never had a sailing boat with 2 x Shore power connections... but I am a yachtie so here it is.
I have just got a boat with 2 shore power connections. It has some Whisper power kit, including a 2.5kW inverter, smart charging etc. It has your normal electrical clalorifier (back up to engine HW) plus 220V sockets. Then the biggie - 2 or 4 kW switchable electrical heating (quiet option to the Hydronic/Diesel) - great at night
- if you have the 2nd cable plugged in.
Now, it appears whoever did the install has put the 220V sockets on the 2nd cable with the heating. (Why??)
So when we arrive in a harbour which only provides a single connection, I end up with cable 1 going to the battery charger --> domestic bank --> inverter --> 220V sockets. Any suggestions on how to improve this? Is it a problem to be regularly using an inverter - its a 2015 model. Some local "experts" suck through their teeth at the mere mention of using an inverter for anything other than occassional use.
I did consider moving some of the 220V sockets back to shorepower 1, but there MUST have been a reason for putting them on 2, what could it be? Am I likely to overload a 16A Shorepower with the Calorifier & Smart Charger?
I look forward to any ideas & input....
