TV problem
Simi
3 Aug 2019
the TV’s are powered by an investor they work ok for 20 mins and then go off for 4 mins before coming back on the investor is on all the time and does not show any faults any ideas what this could be
Do the invertors run anything else? If so, does that remain or off?
Are the televisions hard wired to invertors or on a plug? If a plug, can you plug something else in, and does that go off?
Can you temporarily run the telecoms off 13a shore supply, and if so are they stable?
Failing that, you need to check the output voltage of invertors during on and off phases. They may be overheating or indeed Phuket.
