Piers
Having sorted the TV aerial, the next choice is the TV.
So do we need a Freeview or Freesat TV?
Where are you?
If UK with a normal aerial, you need a freeview tv. To use a freesat box, you need a feed to a sat dish.
Channel Islands. Getting a sat dish for the boat, but now it's whether to get a freeview TV or a freesat TV - I'm confused....
We have both. More channels of rubbish on the freesat tuner, but gives us HD pictures. Difficult to tell the difference in reality. Yes we had about 15 BBC Olympic channels, few of them broadcasting.
which ariel did you go for?
I have a choice of two aerials.
The KVH M3DX or a simple manual dish such as a Kerstan mini*.
The TV will be the Panasonic TX-L24X5B which has Freeview HD.
Choice of Freesat unit yet to be determined.
* Leaving cost out of the final decision, the issue against the KVH is that it would be mounted next to an aluminum based pony mast which would get in the way of any satellite signal from a particular direction. I could always turn the boat around if needs be, but...and another question would be if a received signal would bounce off the ally mast and cause a shadowing on the picture.
Anyone know?
Impossible to get shadowing on a digital signal. The signal is effectively a string of 0's and 1's, so if some are missing then you get a blocking effect on the image.
Thanks jimg - I'm showing my age!
The first TV my parents has was in a large cabinet, took an age to warmup, and the screen wasn't black and white, more like purple and less purple.
Despite my googling to fiond an answer, I'm stuck.
Can freeview channels be seen on Freesat?
If so, which satellites?
Yes and No!
You are getting confused and mixing channels with delivery systems.
The Freeview system which is received through a conventional aerial has these channels:- http://freeview.co.uk/Channels
The Freesat system received from a dish has these:- http://www.freesat.co.uk/what-you-get/our-channels/
As you can see Freesat has the same kind of set of channels and in fact a few more.
It is not a matter of Freeview content versus Freesat content, but more a matter of how you want to receive the media channels.
Does that make sense?
Being a fan of Really (channel 20) I coldn't see it on Freesat or even Sky. Hence the qn.
