Burnham Bob
I know disconnecting the batteries is a no no as the alternator blows, but I have just been on a friend's narrowboat. it has a four cylinder beta and a large ignition panel with the usual lights. the 'instructions' written by the previous owner were clear about starting the engine. but they were also clear that once the engine had started, turning the ignition key off would 'stop the whistle'. as the rev counter didn't work i assumed that someone had done some rewiring along the line, so did as instructed, but realised there were no warniung lights functioning. again i assumed that this was some sort of bizarre rewiring. but my friend now says that revving the engine in neutral stops the whistle. this makes perfect sense as maybe the alternator isn't quite charging on start up but excites itself on revving and the lights and alarms for oil pressure, water temperatire and charging would work as normal - as they do on my boat with a much smaller beta diesel.
so have we done any damage running with the ignition switched off? i have to say that all the batteries seemed to be charged and there was no problem starting.
there appeared to be two alternators and the battery switches were always on in the engine compartment. i seem to recollect the forum advising that switching the ignition off was not a problem but i would welcome advice.
