All I do with mine is tension all slightly at first, then tension forestay and lower shrouds ( I check shrouds by looking how much thread is showing in bottle screws ). Ping all four lowers till all seem same. Tension uppers then lay on hatch and look up to see if any bend apparent, adjust according ( with upper shrouds ). Lay at side of mast to see if any for/aft bend, adjust for/back stay. A slight rake aft is ok. This can also be induced with back stay tensioner when running. Next go sailing and add tension as needed ( if needed ).
