doctormilner
Active Member
I recommend vectran cross cut, incredibly tough and holds shape well, with an acrylic sacrificial strip. Hood designed vectran for cross cut construction.
+1 for Vektran - and I thnk if you go with that then cross cut is fine.
Peter Sanders is a good man for sails for Contessas and the like.
What size Genoa are you looking for?
My current one is 140% - was thinking of going for 135% so slightly easier to tack and less need for reefing.. but I'm still dithering !
My rig is very similar to yours - I found the large 140-150% unsatisfactory as if it is heavy enough to use partly reefed it is too heavy to set well in light airs. I tried something in the 120-130 range but it didn't work with my rig - I lsot 5 degrees or so pointing angle, so settled on a 110% Vectran that works pretty nicely
Thanks. Vectran sounds good, though i think poor UV protection ?
My understanding is I'd only go for a tri in a a laminate material as any stretch will remove the benefits of the tri cut. Cross cut is more forgiving of stretch. On my previous boat I had a tri cut slightly smaller and it was a great sail. It had a foam luff and reefing did'nt wreck the shape. My rationale for cutting smaller was that in light airs if I was off the wind at all I'd be using the cruising chute and I could hold onto it longer unreefed. IMHO the tri cut is worth it.
I understood it is because you are pulling disproportionately across the seams on the front part of the sail, once it is partially furled, rather than along them as is the case when fully unfurled. Happy to be corrected as I don’t claim to be an expert.
Actually I thought the opposite, but can't remember the details. I seem to recall it being used on Clipper boats that go twice rounds the world on one set of sails.Thanks. Vectran sounds good, though i think poor UV protection ?
Yes, just the point made by Pete Sanders in the video clip. It is better to fly a smaller sail which will set well for the majority of the time; roller reefing the headsail has a dreadful effect its performance.
IIRC he says it is sometimes better to put two reefs in the main first - which on a Contessa makes it almost of storm trisail dimensions -).
This is, of course, thinking in terms of flat water speed as a priority. Personally I go for c135%, cross cut, dacron, cut short in the luff for better forward vision.
I am sure Peter Sanders will inform you.
I seem to remember that as well. We bought our crosscut Vectron main specifically for use in the med. and would have queried it. I remember choosing a dark colour for the UV strip on the main. I thought that might last longer than a white strip and Crusader suggested the same thing.
I think that Vectron is made by Challenge Sailcloth using Vectran.
I bought a Bi-radial furling genoa, with foam insert, from Crusader at the same time. It works well and set is still good when I put in a few turns.
Vectan is an LCP fibre which performs poorly in UV. That said years ago Hood (I think) made some decent cloth using Vectran with good UV additives plus a tight weave that seemed to work well. After Hood, the cloth quality collapsed, even on cloth branded ‘Hood’.
Now Vectran is included in a cloth called Vectron made by Dimension Polyant (also owns the Vectran name) which includes a UV protector: https://www.dimension-polyant.com/w.../03/dp_Produktflyer_Vectron_E_-Web.x92783.pdf
That’s why it’s important to know exactly what you’re buying - nothing in theory to stop a cheapo cloth with some added Vectran or other high-modules fibres offered as an alluring ‘boatshow deal’.
Add a couple of Camden Market smooth talkers and the sales if not the sails can be pretty impressive![]()
That's why I was fairly careful at the time and did some reading on Vectron at the time. Pretty certain I found some information about UV resistance and testing carried out. Nothing to stop people printing completely false information of course. Crusader had a good name and the manufacturer seemed to be well known and specifically mentioned steps taken to improve UV resistance.
It was a few years ago and I had a quick look at the firms involved and Crusader did mention both Challenge Sailcloth and Dimension Polyant. I couldn't remember the latter initially but they would have been responsible for the Vectron.
