Daydream believer
I am fuly aware of the time it takes for ordinary brick layers mortar to set having laid a few 1000 bricks over the years. i an also aware that one could use high alumina cement for faster setting. I wondered if someone had access to a different type of "cement" suitable for the purpose. However, if a boat is in water that relies on the tide going out to drain the water then the tide has to be stopped from coming in again some of the ideas quoted are next to useless in the timescale quoted.
Jamming pillows in to a crack on the inside will not be much use either because the crack may only be a few mm wide but long. Such a crack will allow gallons in to a small vessel as the tide rises. Punching in caulking compound could work to an extent.
Stuffing mastic into such crevices may work but the best solution is normally a commercial recovery vessel, paid for with the insurance that the owner should have.
Just stand back & leave it to the experts to raise the vessel & take ashore for survey & further review
