dje67
The teak decks on my Beneteau are around 13 years old. They are the "glued down" type with a sort-of rubber caulking between the strips. Over the years, the teak has worn down a couple of mm, and left the caulking standing slightly proud of the wood. I'm worried that moving around the deck will cause some of the caulking seams to get pulled out.
I'm looking to trim the level of the caulking back so that it is level with the surface of the teak. Anyone done this?
What tools are available?
It feels like I need a really sharp blade that can be drawn along the seam at an angle so that it is slicing the top off the caulking. I thought about using a chisel, but am worried that even a sharp chisel might rip the caulking out. Also, if the angle is not perfect, the cut will be too shallow, or will gouge the teak. I do not want to lose any wood in the process.
Whatever tool is used needs to get in close to the coachroof and toe-rail, so needs to be small and compact. It will also need to be able to be re-sharpened.
Thoughts, please?
Thoughts, please?
