[70521]
Very odd. Goodness knows how they survive.They look round. Not up.
My boat current has LED red/green nav lights on the pulpit, and no anchor light on the mast.
Whilst I have the mast down, I was going to fit an anchor light at the top of the mast, and so thought I may as well fit a Supernova LED Tricolour / Anchor Light, giving me a masthead anchor light, and a masthead option for nav lights.
Is this worth doing to have the option there, or is this overkill?
Well I’m more a fan of lights at deck level - I find that people look ahead rather than up in the sky when close enough to hit me. And judging the distance of a very high light is not easy.The masthead anchor light is the only bit I would fit nowadays, or in my case prioritise the yard to mend. I have a tricolour also not working, but my separate port starboard and stern lights are all LED so tri is merely nice to have
It enables us to find our boat again when moored well off shore on dark and blustery nights.
It reduces risk of us being run down while at anchor as can be seen from greater distance than silly things hanging from shrouds.
It is superior to steaming light if using motor plus sail as doesnt reflect off sail and destroy your night vision as you watch out for crab pots and debris (one aught to suppress stern light as do but in practice no great confusion happens if there are two white light seen from astern)
My only issue with that is that you will be showing two stern lights then - one at deck level and one much higher but that’s not a huge objectionIn the discussions on the merits of fitting a masthead anchor light, I'm surprised that there has been no mention of its alternate use as a combined steaming and stern light for use when motoring (on vessels under 12m).
If I have that wrong, do set me straight since my newly acquired boat has no steaming or stern light.
I think using anchor and tri together would not be satisfactory, so one should have forward facing steaming light if using tri as back up motoring nav light and even then the relative heights would seem odd and maybe confusing.In the discussions on the merits of fitting a masthead anchor light, I'm surprised that there has been no mention of its alternate use as a combined steaming and stern light for use when motoring (on vessels under 12m).
I've nearly hit a boat in an anchorage as I didn't see it or others. From a distance the masthead lights got lost in the street lights and as we got close, getting ready to anchor, you are looking around but not up. It was only the 'shadow' of the boat that alerted us to it being there. It wasn't a stormy night but just dark and no moon.I have a LED tri-white on my masthead and was nearly rammed while at anchor as the skipper/cox of the other vessel wasn't looking out for masthead height anchor lights. I've invested in a "hanging" anchor light as well with an LED Bulb.
I would definitely go for a masthead tricolour because I find the pulpit mounted lights can reflect off the stainless steel and dazzle the helmsman while sailing at night. I find the glow at the top of the mast illuminates the wind vane too. As Topcat47 says above, boats moving around at night in small boat anchorages generally have their attention at sea level and can miss masthead anchor lights so I have an anchor light to hang in the fore rigging - it is LED electric although the oil lamp is still in the locker in case!
When offshore I use the trilight on the mast, as I come into harbour I switch to deck level navigation lights.
The masthead anchor light is the only bit I would fit nowadays,..............
My masthead tricolour is about 6' lower than the sidelights on the Wemyss Bay - Rothesay ferries. Anybody who misses me could be in for a surprise ...I wonder if @Frank Holden could supply a link to his 'from the bridge' pictures of masthead tricolours hiding in plain sight?
Where were you looking as you entered the anchorage?I've nearly hit a boat in an anchorage as I didn't see it or others. From a distance the masthead lights got lost in the street lights and as we got close, getting ready to anchor, you are looking around but not up. It was only the 'shadow' of the boat that alerted us to it being there. It wasn't a stormy night but just dark and no moon.
Probably ahead and even if you do see lights in the sky it’s very hard to tell if they a 50m away and 18m up or 30m away and 4m up.Where were you looking as you entered the anchorage?
From a distance could see the top of a hill but the masthead light just disappeared into the street lights that went up the hill. As we got closer we altered course and the boat was against a dark background; but you don't look up at the sky when entering an anchorage. You are looking ahead and at the depth sounder, etc.Where were you looking as you entered the anchorage?
Can't see why. My boat has the lights she was built with: masthead tricolour, masthead all-round white, pulpit bicolour. I've idly considered adding a stern lightto give me low-level sailing lights.My only issue with that is that you will be showing two stern lights then - one at deck level and one much higher but that’s not a huge objection
