rafiki_
Transport by road should be no more than £1500. You will have to remove stuff from the radar arch plus the props, then replace, so circa £2000 for the whole job.
Using the path measuring tool on Google Earth gives a distance of approximately 660 statute miles! Perhaps there is a shortcut across country via navigable rivers and canals? If so you could cut this down to about 250 miles, but it would take a lot longer!
I used Netpas Distance to get 580 NM.
Isn't it the same thing 580 nm = roughly 660 statute miles? Or have I worked that out wrong?
The only short cut I'd consider would be this one:
Depends where you are in the world really but based on the accepted nm then that's about right
