[159032]
what keeps the brake on once the breakaway cable has broken away.
Why are you convinced that the cable will break? It's not having to lift the trailer and payload, just apply the brakes.
Yes Brian but what keeps the brake on once the breakaway cable has broken away.
It cannot be the handbrake which in my setup is also operated by the overrun coupling.
The last trailer I built in the UK must have been late 70's early 80's
I find now that the breakaway cable is expected to break.
That sounds a bit bonkers to me.
One of the slightly less interesting videos I have seen.
Your coupling was out of date in the early 1970's, it goes back to the days of few trailers going at a low speed. Spring control was very basic but all we had, with the advent o gas filled dampers the world of trailer rakes changed. The only thing we used them on was mobile air compresses, even these were being replaced with damper type over-run hitches by mid 1970.
Fit a new coupling with modern damping on over-run.
Brian
Hi RogerHow does that Energy store work to keep the brakes locked once the breakaway cable has broken.
Hi Roger
Its a powerful spring that holds the hand brake lever on once the cable has pulled it past the "overcentre" position
Reasonably well explained here
My Bailey caravan has a gas strut that pushes the brake on. In order to release it considerable pressure needs to be applied. When the breakaway cable operates, the handle springs up under the gas strut pressure. I have no doubt that should the coupling fail, then the brakes would be applied and stay firmly on!Gor Blimey Guv !!
It still does not answer the important question ... how does the trailer brake stay on after cable breaks ?
My Drascombe trailer has a system like that. It works quite well ... but it has auto-reverse brakes which (duh) don't work in reverse, whether the impetus comes from the car or gravity. In other words, you can't use the brake handle to control it down a launching ramp and the gas strut won't stop it from rolling downhill if it breaks away on a slope.My Bailey caravan has a gas strut that pushes the brake on. In order to release it considerable pressure needs to be applied. When the breakaway cable operates, the handle springs up under the gas strut pressure. I have no doubt that should the coupling fail, then the brakes would be applied and stay firmly on!
Just a comment ... those auto brakes to allow you to reverse the van were very temperamental ! You had to ease the car so slow back to get the van to NOT lock its brakes ... I always reckoned the locking U plate on the hitch shaft was much better ! Number times I'd start backing up and trailer would lock ...
Well suggest that the cable is called a 'breakaway cable' for that reason, its designed to allow the trailer / car to 'break away' from each other when they part company ?I find now that the breakaway cable is expected to break.
Now we are getting somewhere ....
If you have auto reverse brake drums it is essential that you fit an energy store. Without it your handbrake will not work if the trailer is parked on a slope, with the rear of the trailer facing down the incline.
