RichardS
N/A
You have no right to contradict me.
Oooooerrrr ... on that basis we might as well close down all the YBW forums and go home. :ambivalence:
Richard
Frankly I don't really care if you believe me or not. The engine was not running at the time so no HT contact.
As it was, I was there and you were not. You have no right to contradict me.
If you want you can come and examine the scar on the palm of my hand, still there after nearly forty years.
The bad shock I experienced was when working on a car engine I lent on the engine and accidentally on the poss terminal of the battery at the same time.
No, the engine was not running and there were no tools or other bits of metal involved to heat up. It was a high capacity battery in an old Morris Oxford - if any of you remember what that was.
I can't believe the timing of this thread... Last week I was taking out the battery from my rib using my trusty Chrome Halfords lifetime warranty combination spanner. Yep...you guessed it. as I was undoing the negative bolt , the spanner also touched the positive. The spanner welded in place and within two seconds it was cherry red,within 5 seconds it was bright orange. I kicked it off the battery with a screwdriver and threw it on the ground. I shouted to my mate. It took him 20 secs to come over. It was still cherry red! The spanner is now s shaped and a blue colour. You have been warned.!!! Should I bring it back to Halfords? Nik
Was the engine running? The LT side of the coil can easily spike to 90V, particularly if the capacitor (in a traditional distributor) is on its way out. Same principle as a "joy buzzer".
12V is plenty if correctly applied.
For TENS (Transcutaneous Electrical Nerve Stimulation);
- Body resistance is given as 150R to 500R using typical sticky pads. (Not via the hands though, pads are usually fitted over the muscle group to be stimulated.)
There's a well known "party trick" of dropping a big lump of wire wool across the top of a battery. Once you've seen that you'll always make sure batteries are properly covered or boxed.
What is "R"?
Richard
What is "R"?
Richard
- Seen as a load, the body looks capacitive, which is why TENS machines use AC.
- Stimulation depends on current density, current and pulse duration. As a rough guide, for a 100us pulse;
* Feel it above 30mA.
* Muscle motor effect above 50mA.
* Painful above 70mA.
Given that;
12V / 500R = 24mA
12V / 150R = 80mA
There are muscle groups in the hands.
Then;
Contact via the hands must usually present a much higher resistance.
Also;
The apparent capacitive nature of the body when seen as an electrical load at these voltages is due to biological changes which are reversed when the current reverses.
Since a 12V battery isn't AC, the current on initial contact will quickly fall.
In order to stimulate a muscle, the skin contact region must result in a current path through the muscle nerve fibres at a high enough current density.
So;
Quite a lot of conditions need to be met in order to stimulate a muscle with a 12V battery.
It can happen, but not very often.
Seems to fit the observations here.
What conductive goo is on the pads? How does it compare to sea water?
Why are you measuring capacitance on Ohms?
What would the capacitance be for the sticky pads placed each side of a bit of paper?
from your graph
10uS equates to 100kHz effectively RF, things are very VERY different at RF
while the other end 1000uS is a mere 1kHz, still significantly different from DC or even mains.,
Yes, these are pulses and an initial contact MAY be equivalent to the leading edge of a pulse, but that would require the victim to perform a significant electronic test of the input signal to determine the shape of the leading edge: was it a quick, firm contact or was it more a slow brush?
It's electronic notation for Ohms. The letter is placed where the decimal point would be and the letter denotes the multiplier.
EG
500R = 500ohms
50R1 = 50.1ohms
2k7 = 2.7k ohms
27k = 27k ohms
5m1 = 0.0051 ohms
and so on......
I'm familiar with the k and m convention replacing the decimal point and familiar with R representing resistance but I have never heard of "R" as a direct replacement for "ohms".
Can you provide a web reference to this R convention?
Richard
Richard
