Birdseye
smallish boat so the keel bolts are about 19mm stainless. Hull is solid GRP so what would be the torque wrench settings?
Bolts are torqued because its impossible to put a nut on them without applytng a torque, surely?Bolts are torqued to stretch the bolt to make it more resistant to fatigue failure with cycling loads. Very necessary on a cylinder head bolt. As with the cylinder head bolt the bolt is stretched against the solid cylinder head.
I don't think your GRP hull would be capable of withstanding the crushing force needed to stretch the very large bolts. That means that you simply tighten the bolts to a torque that will stress the threads and hold on over a long period. The bolts themselves will be over sized to give a long life despite any corrosion. So IMHO opinion and I hope not contrary to Viv Cox I would do them up tight to a torque that seems appropriate with a suitable sized spanner. Certainly not too tight. ol'will
One of those tables has an accompanying note sayingSome thoughts and data here Keel bolt tightening torques
....You seem to be conflating the term with the use of torque-to-yield "stretch" bolts, a special case, and one that I'd guess doesnt apply to most bolts used on most boats.....
Exactly what I said. Confusion with specific things that arent relevant is pretty much what "conflation" means.There's no conflation, all bolts stretch when the nut is tightened. "Stretch" bolts are a specific thing, and not relevant here.
Some of the hull bolts go through mild steel washers and the windows have at some point leaked. Rust! So the nuts need removing when the boats on the hard and the keels are on the ground. Replace washers and re-torque. Already done some without problemWhy do you think they need checking? If they were correctly torqued when new and the keel has not been removed there is no reason why they should have changed.
What is the material being compressed to give these number?You would not go far wrong with this guide
Bolt torque
There is such a thing as creep. I know this happens in steel but I havent a clue how grp respond to crushing loads over 20 yearsWhy do you think they need checking? If they were correctly torqued when new and the keel has not been removed there is no reason why they should have changed.
You raise an interesting question - why do we torque fasteners. I guess there are several reasons: firstly putting the nut under load makes it less likely to self undo under, for example, vibration. Perhaps less relevant in the era of nyloc nuts but not totally irrelevant. Second reason I guess is to ensure a firm joint between the surfaces being bolted - tension in the keel bolts makes the keel less likely to move and counteracts the upward movement of the hull because of waves. Thirdly tension in the bolts helps ensure a good leak resistant joint. Fourth - with dissimilar materials, working to a set torque avoids crushing one component, for example alloy wheels. But above all, using a torque wrench to a set standard avoids necking the bolts - something which I have done several times.Whether keel bolts are one of the critical exceptions (like, say, head bolts on an engine) which need to use a specified torque I'm not sure, not having much personal experience with them. They certainly seem important, but there also seems to be a fair bit of redundancy in most designs, many of which will have been commissioned long before torque wrenches were much of a boatyard thing.
Oh goody. Another variable.Some of the hull bolts go through mild steel washers and the windows have at some point leaked. Rust! So the nuts need removing when the boats on the hard and the keels are on the ground. Replace washers and re-torque. Already done some without problem
Any minute now I can see the forum torquing b..xOh goody. Another variable.
Should the torque spec (if there was one) be modified for use afloat?
Ummm...Probably not.
But I suspect there isn't really a torque spec. anyway.
Well, you might, because those figures, from a bolt seller, only consider the torque those bolts (respectively a medium carbon and an alloy steel, neither are stainless) can safely take. They can take no account of the loads the tensions implied by those torques are applying to the substrate, because the substrate is unknown to the seller.You would not go far wrong with this guide
Bolt torque
The OP says he's "already done some without problem"Why do you think they need checking? If they were correctly torqued when new and the keel has not been removed there is no reason why they should have changed.
Several of the tables on that page of my website are specifically for keel bolts. In general it seems that the figures are downgraded from typical values for steel applications but not by very much. GRP thickness at the keel is usually quite considerable, at least on older boats, and with loads spread by the conventional large washers I doubt that the risk of crushing it is high.One of those tables has an accompanying note saying
"These values are for well-greased threads.", which is nice, and unusual. The others dont say, and they would probably and generally be assumed to be dry.
The same note also says "The user is cautioned to use good judgement in applying these values." It might be uncharitable to consider this a CYA cop-out, but together these two factors suggest these figures only provide rather general guidance, and that snugging up by feel might not be so very bad after all.
There's also a note from the page compiler, accompanying the first table, saying "In the event the owner was not present when the keel was re-bedded and the yard told him they just tightened them as hard as they could!", which, together with the recommendation not to over-tighten on softish glassfibre, suggests snugging up by feel yourself might be better than getting someone else to do it.
