Torqeedo Travel 801 Recell
StefanSG
10 Feb 2021
Gosport
I asked in the forum last year about getting hold of a dead Torqeedo that I could revive, I bought a non-functioning one on Ebay and I've successfully recelled it. I had to buy a long Torq15 driver to open the pack and this is what I found
possible seawater ingress causing ruptured dead cells. You can see a shiny layer at the bottom of the pack, this is a solid rubber based sealant that holds the pack very securely in the case. I sent this picture to a chap called Lars in Germany who makes battery packs, he advertises on German Ebay and sells an off the shelf pack with a different layout (see Ebay item 323885661561 or Seller akkuservice-dellinger) the price he quoted of 290 Euros included shipping and 2-3 weeks later a brilliantly wrapped and very solidly made pack arrived which fitted perfectly. He uses identical spec batteries to the original, 8S8P Molicel INR18650-P26A which make a 20,8Ah pack which is an improvement on the original
Getting the old cells out was relatively easy although messy and hazardous, especially as some of the cells still held a charge. The sealant stuff peeled away from the base relatively easily... in the later models they use a more brittle material that takes a bit more work.
I wanted to install a BMS and finding one that matched the spec of the battery (8s 29.6v) wasn't easy but there is a company in China called RJXZS who sells one, via AliExpress. Its a 50A BMS and cost about £26 inc shipping. BMS 8S 29.6V
There isnt room on top of the pack to put the BMS but luckily this BMS is pretty small (70mm x 70mm x 9.5mm) and fit into one of the "wings" of the battery case with a very minor bit of chopping.
I used all the original + wiring which was in good shape and put in a new - cable which needed to be slightly longer to reach the BMS, but followed the exact same wiring as the original pack. I left the original charge/battery PCB & indicator exactly as it was. I plugged it into the original Torqeedo charger and left it charging overnight (checking periodically that no cells were overheating) and it charged up to 100%.
I used Bond-It black polyurethane PU18 sealant to fix the battery pack back into the case and to seal the tongue and groove around the lip of the join.
This was all back in December, I left the pack till now (about 2 months) - still at 100% despite the cold. I had to do a minor repair on the "kill pin" which someone must have tried to substitute with a pencil or a screwdriver and had bent the safety switch which was luckily an easy fix.
I tested the motor today, I was worried that the BMS would cut out with a surge in power but - in my recycling bin - it performed brilliantly.
I really like the design of the travel it all packs up into a small holdall like an overnight bag. When I get a chance I'll test on the water and see what sort of range I can get, but its more than adequate for my needs to drive a yacht tender.
feel free to ask any questions, criticise my soldering etc.
StefanSG
DISCLAIMER: I am not an electronics expert. I am a hobbyist who has made up a few Li-Ion packs in the past for tool batteries, electric scooters etc and made my own battery welder from an old microwave transformer. I would sincerely advise using a professional such as Akkuservice to make up your pack. Take the utmost care when soldering up these packs as they will spark, burn, melt metal and cause noxious fumes. Opening up one of these packs of course goes against the Torqeedo ethos and will void any warranty and can be potentially very dangerous. I have posted this for information only, please use common sense when dealing with lithium packs.
Brilliant write up, thank you.
How was the battery pack originally sealed? I'm not sure I'd be confident of getting an adequate seal when reassembling. If I recollect, Torqueedo claim that the battery packs of some of their current models are so waterproof you can dunk them fully under water.
I'm not sure. At some stage someone had opened the pack and tried to reseal it with some black sealant, so not sure what was originally there. These older generation batteries are definitely not waterproof in any way, you can see daylight from inside through where the electrical connection is, they wouldnt survive immersion.
Fascinating , well done.
would love to modify my throttle to make it less sensitive if you have any solutions.
I’m sure you’re aware but the early ones were recalled by Torqeedo as a fire hazard. Mine caught fire 5 hours after use and they kindly replaced it with a higher capacity one, foc.
Yes that’s why I have installed a BMS. While researching the construction of the battery I found the Torqeedo web page with the serial numbers, and mine was eligible for a replacement. Sadly after enquiring with them, it seems that offer expired about 2020.
I took a look at the main control board while fixing the kill switch, the mechanism couldn’t be more basic, the throttle has a little flexible coupling that turns a potentiometer that’s soldered to the board, with a bit of forensics you might find a better replacement, I’ve see a few later throttles on Ebay pretty cheap.
Nice article. I think that in a year or two I will have an electric outboard for the dinghy and keep the battery topped up by the boats solar panels.
Can I say that these batteries (apparently) don’t like to be kept ‘topped up’ unless used all the time...they should be stored at a lowish charge
I keep in mind that the lives of these type of batteries is measured in the number of recharges you give them. That and the fact that they can be pretty deeply discharged and accurately measured means I’m going to charge mine only when it gets to 20%, and charge to about 80% to overwinter
Lithium batteries lose a small amount of capacity every year - even when not used. After 9 years, our Torqeedo battery was down by about 30% so I replaced it with a larger (somewhat expensive) replacement. Best advice for long term storage is to leave it at around 50%. Do check occasionally that internal current drain hasn’t dropped the state of charge too far. You could say that this is a ‘hidden’ cost of electric propulsion…
I bought a brand-new Torqeedo 1103c in February 2021 which I haven't used yet. It has been kept in a clean, dry environment, ie the spare bedroom.
What should I be doing to prevent its battery deteriorating whilst in storage?
Keep the charge about 50% and check every few months that it hasn’t dropped
Any ideas how can I discharge it without running the motor? At the moment it is at 100%.
It is not good to run it dry and I don't want to get it wet in case I decide to sell it unused ?
Two golden rules, don’t discharge it and then pack it away, and don’t leave it on charge.
The E-Propulsion automatically discharges the battery when stored. Get a cable connector and charge your smartphone with the Torqeedo battery
As an addendum, I field tested the Outboard about two weeks ago. 6 months later, the battery was still at 100%. The outboard worked perfectly for about a mile at max rpm with no issues. I'll leave the battery without charging, to see what my likely range is. I have also acquired another 801, with 2 immaculate but dead batteries, for my next project !
