That was a charter boat, and I have set my own dinghy up with the bridle arrangement so if something came undone on the dinghy, I've got a second line there.Another top tip, Tie a bridle to the D rings which are normally fitted lower down than the handle, and tow with a rope attached to that. Retain the painter attached to the handle but very slightly looser as a secondary / safety rope.
Oh and remember / look behind before engaging engine in reverse
PS. Must have been some curry!
This reminded me of a conversation had between myself and my wife just off of a Greek port, just after I'd opened the holding tank seacock:Two tips, use a long line so it lays flatter in the water, less drag. Second tip, secure to cleat on opposite side to black water tank outlet
I only copy others as it seems to work for them. This is after a decade chartering multiple times in Greece, Croatia, Gibraltar, BVI, Bahamas & the Whitsundays.mmmmmmm first thoughts ... what are you doing with an inflatable on such a long painter ?? Inflatables should be hauled up against transom - to stop them flipping over in seas. Hard dinghys are towed on long painters.
Therefore I call into question the OP's 'top tip' .....![]()
My thoughts exactly. The pull on the line is dramatically reduced when I do that.mmmmmmm first thoughts ... what are you doing with an inflatable on such a long painter ?? Inflatables should be hauled up against transom - to stop them flipping over in seas. Hard dinghys are towed on long painters.
I believe that 2 waves back was the old seamanship rule - but back in the days of heavy clinker built dinghies, to stop them crashing into the stern of the mother ship.I have read, and tried to achieve, that a painter should keep te dinghy just in front of the peak of the second or third stern wave so it's always going downhill and not causing drag. I can see the logic but my own observations are not convincing. And why not the first wave? I can't remember the source for this nugget.
If I'm tacking up a narrow channel, you'll be lucky to get 20cm to spare, if you're motoring. You're supposed to keep clear, though I am all for give and take where possible. Keeping your tender close when in a narrow channel is a part of that give and take, if you must tow it. We never, ever tow ours. It's inefficient, potentially dangerous, you might lose it, and it slows you down. It's one of my pet hates, it makes my teeth itch to see it done. Unseamanlike, IMHOI have towed a dinghy for years, the only time it needs to be at a distance is in a big following sea when it surfs down the waves and tries to head butt the transom of your boat. Apart from that someone tacking down a narrow channel will probably not see the painter and try to get in between. You know what they are like, they try to miss you by a couple of meters if they can.
If you’re sailing, sure. I did mention motoring. If you’re sailing on starboard, you do indeed have right of way, and I’d let you know I was taking appropriate action. Of course, if the close hauled boat is on starboard, you’d be windward boat and should keep clear. But surely there’s some give and take, nobody should make life difficult on purpose. The only time we have any trouble in this scenario is when we are, by virtue of our speed, keeping pace with someone who is motoring to the same general destination, and we’re repeatedly crossing them. That is a pain in the ass. Solvable by the motoring vessel speeding up or slowing down for a bit.And if I am sailing down the middle of the channel on a starboard tack, minding my own business, the boat charging at me on a port tack still thinks he has right of way.
Poor sailing in my opinion.
