Tool Kit
The kit shown in the link is OK-ish, but the case is waste of space. An ammunition box is very useful for keeping them in; the type whose lid has a neoprene seal and a big over-centre clip to keep it closed and exclude the salt air. This sort of thing:View attachment 98500
I would just buy a selection of screwdrivers, pliers, add vice grips large and small , perhaps an adjustable wrench, a strap- or chain-wrench for screw-on filter elements, a set of combination spanners, a set of allen keys, a hammer, junior hacksaw, (big screwdriver for doing damage:) ). It might also be advisable to include one of those little magnets on a telescopic stalk, and its cousin, the extendable mirror. A socket set is also de rigeur, to include a range of smaller sockets with 1/4 inch drive and their dedicated ratchet and extension bars. Add a hacksaw (and spare blades) if you don't already have one as part of your emergency equipment. A micrometer, either digital or analogue, is a useful thing to have on board, for measuring various things, and a measuring tape. Don't forget a cordless drill, drill bits screwdriver bits and a MAGNETIC bit holder.
At this point you need to examine all the systems and fixings in the boat ensure you have tools to adequately deal with them all.
I'm going to go to the boat now, and see if I missed anything:)
Brilliant stuff
I prefer a roll, something like this will take all you need for everyday use and most servicing. I never liked Ammo boxes - too deep and narrow and only one compartment, you have to tip everything out to find what you want.
C.K Tool Roll T1718 | C.K Tools Superstore
Too true, although my ammo box is full to the brim, so no space wasted there, and my most-used tools are always to the top. You have made me consider combining the two; a roll for spanners and a roll for screwdrivers and pliers, both contained within the box, then the other items can rest at the bottom until needed. An oily roll will help to keep rust at bay.
I see 50 screwdriver bits in that kit. You will probably need 4. And it will be the ones you don't have!
I'd expect to need at minimum pozi 2, pozi 3, phillips 2, at least three sizes of flat, two or three different Torx for Selden stuff, allen 3 - 6, not to mention a "jeweller's" set for electrical cases and terminals.
You don't need the really big sets with all the different security types, but a bitset with a decent range is definitely necessary (unless you want to carry a big bag of screwdriver handles around).
Can I add a vote for a range of extension pieces for screwdrivers? There's always one screw that needs a long reach to get at it, usually holding something where the other screws need a stubby screwdriver! And a ratchet screwdriver is essential in many places where you can only get a fraction of a turn at a time.
Kit looks like a false economy. It takes up space and most likely won't last the course.
All above suggestions are good. A flexible screwdriver with a socket for jubilee clips...plus some spare jubilee clips...is a good addition and is maybe the non-obvious tool I use most frequently. Saves significant time compared to fiddling with a flat screwdriver when contorted in a small dark space.
the silverline roll of spanners is really good
Socket set is the one major tool not really worth scrimping on. In my experience cheap sockets and their ratchets do no favours to anyone. I splashed out on the bahco set, on an engineer recommendation. and I think it'll last a lifetime.
I also have a filter spanner which is really good.
Also a butane cutting/soldering knife. Makes trimming ropes a doddle and has many other uses e.g. heat shrinking electrical cables.
Flexible drill extension, boom. Doubles as a screwdriver.
Of course, the other essential accessory is the 6" dwarf with 5 foot double jointed arms and a grip like a gorilla!
Mechanics hammer, large and small hacksaws and Stillsons 8" to 18" are my most used tools. I store them in a Rolson tool bag as it is easy to stow. I've got an old Bosch battery drill and full set of bits which is handy but I can't charge it on my boat. Don't carry tools you won't use they're heavy and take up space.
