melvynpatrick
I have two Blake’s toilets on board. Not the lavac, the big old bronze ones. They both work beautifully. The forward one is below the waterline. The inlet water is through a Blake’s seacock and then to a tap (sic) on the back of the toilet. You keep the tap closed or the inlet water fills up the toilet and then the rest of the boat. For belts and braces you can close the seacock too. Because guests often forget to turn off the tap I decided to fit a siphon break from force 4. This works a treat if people forget the tap. However when flushing the toilet it sucks air too much and you have to put a finger over the valve so you can pump water in easier. This is a bit of a nuisance. Is this phenomenon just inherent in anti siphon loops or have I bought the wrong one. Thanks.
