Tohatsu 6HP 2 stroke Outboard Oil Change
AshbyGirl
22 Dec 2004
Can anyone tell me what type of oil to use in the gearbox please. Is it ordinary engine oil or something more sophisticated?
Ask a Tohatsu agent.... but I would have thought it is outboard engine gear box/leg oil. Don't know the Tohatsu but you normally fill the thing from the bottom hole until it comes out the top on an outboard so you need a squeezable bottle with a pipe fitting or a little pump....can be bought at most swindleries.
SAE 90 ie gearbox oil-lot thicker than engine oil. Can get it from Halfords, many garages. Just changed mine-screws were very tight & as Howardp says you have to pump it in the bottom until it comes out the top-need a small flexible pipe to fit in the bottom hole-the one that comes as standard with most bottles of gearbox oil is too big. I had to loosen the screws with light taps with a hammer on a large screwdriver-guess animpact driver would do as well . Hope this is of help
