rogerowen
We have acquired this engine and it was fine first time out - just a short trip from slipway to our swinging mooring (about 3/4 of a mile), and back again, all fine. Cleaned the motor in fresh water in a wheelie bin without a problem. Then, went to use it 2 weeks later and it was seized solid, could nor pull start at all. Have un-seized with 3 in one oil down the bores and turning gently until moving relatively smoothly (still a bit 'dry' sounding). Back to the wheelie bin, and it started first time, runs fine at tock-over, water coming out of the drain pipe but not getting past Luke warm. Engine block is warm to the touch but not HOT. Open up the throttle, runs for a bit - then dies, and will not re-start for a minute or so. I'm running the engine with the cover off - but it sounds mechanically 'dry' when running, quite noisy. I've had a look down the plug hole with an endoscope and can't see anything obvious. I've increased the fuel oil mix from the recommended 50:1. As the block doesn't seem to be getting excessively hot, I'm not sure if this is seizure, but the 'Dry' running noise might point to some mechanical issue. Anyone experienced the same issue?
