Seastoke
Cut out when reved cleaned carb now will run on lot revs open her up and she dies , any ideas
The right way to do it is using an ultrasonic bath, but I didn't have one so basically, I took it apart and cleaned everything with a toothbrush and neat petrol. Pro tip, don't do it indoors! Pro tip 2 Don't poke wire into the jets to clean them - they're quite soft metal and made to high tolerances, a scratch could mess up the calibration permanently.How did you clean the carb?
The right way to do it is strip it to bits and clean it with carb cleanerThe right way to do it is using an ultrasonic bath, but I didn't have one so basically, I took it apart and cleaned everything with a toothbrush and neat petrol. Pro tip, don't do it indoors! Pro tip 2 Don't poke wire into the jets to clean them - they're quite soft metal and made to high tolerances, a scratch could mess up the calibration permanently.
Could be as simple as fuel, If the mixture is wrong, or old it can cause this. Try putting choke on a bit, and feathering it to the throttle. Also leave it running at tickover for a bit to warm it up.So we are in the middle of a bay so not many stuff , but I stripped carb down cleaned all of it ? And now it runs on tick over , if I increase revs it cuts out .it takes me ages to get ashore
How do you get it outFuel filter is in the shape of a fine gauze over the pick up pipe in the bottom of the fuel tank.
Ty cockNGK BP6HS-10 or BP6RHS-10. Gap is 0.9 to 1.0mm
Where are you? Conwy chandlery, ABC Marine, Yachtshop Holyhead?
Halcyon days, very envious.Ty cock
Thanks for looking but wrong carb , ours is 2006 2 stroke 3.5 up model m35b2 thanks againHalcyon days, very envious.
Try Menai Marine, Vicky Dock, 07980872729.
Does this help, found via a quick google search.
can anyone load an image of the carb in pieces
