stuartwineberg
Here's the story
Decreasing amounts of water from piddle tube but always starts second pull. This years fuel mix - approx 50:1
One day works fine for 20 mins and then refuses to start from warm. Cleaned out the carb - no change. Off to service centre. New impeller, waterways cleaned out. Test run fine in tank.
Next time out - 20 mins fine, loads of water from piddle tube. Then wont start from warm
Now wont fire at all. Not the kill switch - have disconnected it. Fuel getting to the plug - its wet when I take it out. Some sort of a spark when tested against the block although not what I would call "fat". I suspect compression or HT - what do you all think and what to do?
